A faster hard drive would just be a waste. The system uses a National Semiconductor PC87415 IDE controller, which has a maximum data transfer rate of 16.7 MB/s (PIO 4 transfer mode).
Heh -- I was pretty close then with my SWAG of 15 MB/sec.
Heh -- I was pretty close then with my SWAG of 15 MB/sec.![]()
My point exactly.
Edit -
Thank you matt. This is what I was looking for. Now with this information, the speed of the device used hardly matters. However I do want to point out one last thing just for the record. Choosing between a HDD and a CF card as a replacement still remains a personal preference, and I'll explain why.
Depending on the situation, and how often the game will be used, a hard drive may be better in certain situations. I, personally, am a collector. However I don't use the arcades I have that frequently. Make no mistake, I love them, but I'll play them when I have friends and family over, I'll play a few games every now and then, etc. Sometimes I'll play them for a few days, sometimes I won't touch them for a month or two. If I kept this behavior up for 10 years, the hard drive would outlast the CF card. Take this for example: If these machines shipped in 1999 like they did, but with CF cards already in them, then right now I would be replacing the CF card in there not because I want to, but because I have to, as the CF card loses it's data retention after 10 years. The hard drive wouldn't have this problem. Think of CF cards like a CPS2 suicide battery that lasts 10 years, and if you forgot to backup your drive, that information is gone.
Now in this situation, a CF card may be better: Say you have people over on a regular basis, you play these games by yourself frequently, or you have them all on at once for one reason or another. This is where the CF card would be better. If you play these games frequently a hard disk will begin to fail much sooner - the majority of the wear and tear put on the drive is when it's turned on and off frequently. Also, depending on the cabinet, it may be better to use a CF card as a new hard drive will heat up, and if the proper cooling isn't installed this would also lead to failure.
So now we know that speed isn't an issue. I've had my question answered, and I hope this thread has helped others as well! Thanks to everyone who chimed in![]()
teckkev - I was referring to how he fit a 6GB image on a 4GB drive. Something doesn't seem right.
I suppose the matter is personal preference. CF cards have a lot of advantages, but they have their disadvantages as well. Personally my Quantum Fireball is as quiet as could be so noise isn't an issue in my case, and the drive is still cool to the touch even after being turned on for a good hour or two (I can't say as much for the Western Digital drive I tried throwing in there). I'm tempted to believe that the life span of the game may actually last longer with a new hard drive in there than if I used a CF card - as if I didn't use the game or stuck it in storage for 10 years, the information would still be there, where as most CF cards have a data retention span of 10 years.
The only thing I'd want, if anything, is for the games to switch faster. Not necessarily boot faster, but load faster between games. It makes me wonder how much faster my Sportstation would be if I stuck a 7200rpm drive in there instead. I wasn't able to get my WD 7200rpm to load using chdman.![]()
I could be wrong, but I beleive the "10 year retention" has to do with the flash cell holding the state with the power off. Not that the flash card will only last 10 years...
Wow, I thought this thread was over a few posts ago... Everything that was said after my last post has pretty much already been said - so I really don't understand the need to say them again - but to each his own I guess.
I don't know where to begin. This is the best example I could give you regarding how I feel on the situation. The other day I found a bunch of hard drives in the garage from when I was a kid. 6 or 7 drives just laying around from various computers my family and I had growing up - we're talking 15+ years old. Out of all of those hard drives, only 1 of them didn't work, and it was due to a faulty diode on the drives PCB.
Now Vector you're saying that the data retention span on CF cards is a minimum. There are two things that bother me about that - the first thing - that every manufacturer I've seen lists, "Data Retention of 10 years". Surely if they meant these drives had a *minimum* data retention span of 10 years, they would have simply said that? "Data Retention of 10 years" does not tell me, "Minimum Data Retention of 10 years", it tells me data retention of 10 years, meaning after those 10 years, that's it. So where did the minimum come from? I'm not saying you're wrong, I'm just saying why make the assumption? Take this for example: say you buy this CF card to put your personal data on - are you really going to trust your important personal data on an assumption that the DR span is a minimum? And the second thing... even if the DR span is a minimum, how much longer would it last? A year? 2 years? Does anybody know? But, if that hard drive doesn't get used all the time (similar to how the factory hard drive was in my machine when I first got it), that drive could potentially, best case scenario, last me another 10 years. In other words, if a hard drive isn't being used, it isn't wearing out. If a CF card isn't being used, it's always wearing out, albeit over the 10(+) year time span.
I just really think the whole, "omg, hard drives are so terrible" thing is really quite exaggerated.
Don't get me wrong. If I was being one sided, and only wanted everyone to do what I believed, I wouldn't have made that post listing the cons for what I believe! I'm just trying to point out the different scenarios in an effort to help other people make a decision. Maybe in my situation, me wanting to use a hard drive means I'm not as good as a collector as the rest of you guys, if I'm sort of planning for my machine to be off as much as they have been. You know what, I'll probably just do the best of both worlds - I'll get a new hard drive, and a CF card setup, and just keep one as a backup. Yeah, I like the sound of that.![]()
I think the others did a good explanation of the retention issues. In general companies provide product specifications that they can exceed to have a buffer between real-world use and published specs.
Now is the time to panic since CDs/DVDs are going to last less than 100 years and they may be storing your personal data!![]()
