is this number for the chassi or the tube?
jbaker
Arizona
I found it in the bottom of the cab I don't know what it stands for only wells gardner something I don't know what it fell off of thanks
WGR2550-U4GS20J
054A5191-009 its just a small white tag.
That fell off the monitor main board. It tells that you have a Wells-Gardner model U-5000 monitor. Tape it back onto the monitor near where the power cord connects.
are these parts compatible
ok modessitt say I probably have a modified u5000 chassi because the 25k pins are missing
here is a chassi pic. http://img838.imageshack.us/img838/4951/cimg1445c.jpg
he also says my yoke looks like a K7000 series yoke in this thread.
http://forums.arcade-museum.com/showthread.php?p=2169418#post2169418
here is a pic of my yoke and tube can anyone verify this is a k7000 tube and yoke.
yoke. http://img716.imageshack.us/img716/5797/cimg1442o.jpg
tube. http://img84.imageshack.us/img84/7684/cimg1440o.jpg
i do believe modessitt is correct but I assumed a k7000 series was not compatible with a u5000 series mabey I am wrong. I bought a new k7400 chassi from arcadecrt it says to use a . #009A2988-001 yoke. can I use this 25inch k7000 series tube with a K7400 chassi if I can find the proper ( U5000/K7400/U2000)yoke.
the u5000 chassi an tube and yoke were connected in a deer hunting cabnet that played blind.
if you got a Zenith tube, they should all be interchangeable, permitting you have the proper yoke. I used to know, but after years of reading things and my job burning me out, it's hard to keep track of what yokes go to which chassis.
I think the U2000 and K7400 are the same yoke, cause they're both standard res. U5000 might have its own shit, which is confusing cause I would think it would be the same as the K7500 cause it runs medium res, but the U5000 and K7500 do not use the same yoke. the K7500 out of my Blitz 99 actually has a label on it that says to replace the chassis with K7500 only, and I'm thinking that exists because of the yoke. also be mindful there were multiple revisions of the K7500, there's a K7501 and a K7502, each using a different yoke. I can't remember if the K7400 shipped that way too.
I don't know 100% for certain, but maybe the K7000, U2000 and K7400 all use the same yoke..?
thanks mecha my yolk is bad it shoots a tiny spark out from right under the letter s on my yoke, I will have to try and find a good k7400 or u2000 yoke to try.
