Is this an easy fix?
Mario64
Texas
I recently installed a Wei-Ya to replace my a k7xxx. I have been reading past threads about these and it seems that everyone usually has the same issues.
1. The image is upside down.
2. The image is mirrored.
3. An issue that needs to be fixed with the isolation transformer.
I have been able to resolve all the issues except for one. Could you guys possibly help me out. This is my current screen image.
Thanks in advance.
your yoke connectors are turned 180 degrees. you must keep the horizontal connector on the horizontal yoke pins and you must keep the vertical connector on the vertical pins but you can turn each connector 180 degrees and put back on the same pins.
Hey man. thanks for the reply but could you help me understand what you mean. Out of the box I had to flip the YELLOW and BROWN connector to get my screen reading from left so that is fixed.
The problem I am having now is the image is split up into 3 separate images (as pictured) are you telling me to turn my RED and BLUE connector 180 degrees and plug it back in?
Im confused.
if you have three images on the screen than i would check to see what sync / resolution your running. (that wei-ya chassis will accept different resolutions i am pretty sure so you have to make sure what your outputting from the game pcb is the same as what the chassis is set to).
