I have a monitor with a snapped neck that I acquired today. I think it is a Kortek chassis but I am not 100%. Also, the monitor frame is black and really thin metal.
Thanks!
Tom
Thanks!
Tom
it looks very similar to the KT-1420A which always had its number on the solder side.
Thank you. I will take it out of the frame and check for the model number. Is this chassis directly compatible with any typical tubes (G07, 4600, 4900, k7000, etc...)
Cheers,
Tom
Most companies did not use the same tube
on every version or the chassis line.
Check {manuals in general} you'll see in some cases a list of tubes
can be found.
Any part numbers on the tube?
Yeah: A48ABK05X
Looks like the same type as a K7000
