Is this a k7000 Tube?
Fudd
Kalamazoo, Michigan
got this tube for $3 from an auction...its a 8 pin....horizontal = 3.4 vertical 16.1.....can i use this for a k7203 chassis i have? the neck is long a skinny compared to a cr23
It is a K7000 pinout (CR-31).
The 7203 had these yoke readings:
Horizontal - 2.1 ohms
Vertical - 15.8 ohms
Looks like the vertical is fine. Horizontal is off a little, but you may need to do some adjustments to get it looking right...
so i should have no problem at least hooking it up using the current yoke but i may or may not be able to adjust it in?
That tube will work fine, just make sure to mark the conv rings so you put them back in the same spot. Try to use the TV yoke and if it works great! I have a bunch of those tubes with almost the same ohm yoke and I never got them to work so I just used the 7000 yoke instead.
