Is this a dixie narco?
SilverDuck
Minnesota
clas_general_172232-20090601210906-1.orig.jpg_290_290_border_3_1
Is this a D/N, and if so, what model?
tia
Seller said the coin mech works 50% of the time. How much trouble/expense will it be to repair/replace the coin mech? What is a fair price on this used machine?
Coin mech repl is 2 plugs and mabye loosen 3 screws if they were tightened (just hangs on slots). Should be able to find a mech for 100 or under on the bay, but you would have to make sure it has the pigtail hookup for the validator. I would probably try to get the machine for under $100. Guy would probably like to get it out of there. It has a specific juice brand graphic , therefore worth less. Where are you located?
This machine is in Pennsylvania. Seller is asking $100. Should I try to get him to lower the price?
Always try for lower. Go with $100, offer 50 and go from there. Make sure it gets cold though. Where are you located? I have a couple machines in Mass.
The side plate has a big scratch in it, but I can make out Model # ?60/210-6.
Is it most likely a 360/210-6?
The first number (?60/210-6) is scratched off.
I just started to play with this thing, and I'm not sure if it cools at all. It's been chuggin for a few hours, and it don't seem to be getting cold. All the sounds are there, but I am not sure if it's cooling.
Is the "compressor deck", as sold at Vending World, etc...is that all of the refrigeration parts? Is it a sealed unit, where I can just buy it, bolt it up, wire it up, and go? Does it require any special tools or equipment? Are there any refrigeration parts not included on a "compressor deck"?
images
