Is there an ARII "How to test" guide?
HighScoreSaves
Donor 7 years: 2013-2019
Blaine, Minnesota
I was looking through the search and was wondering if there is a guide on the ARII's for Atari?
I am looking for step by step. Something that shows if "a" is not working, check "b,c and d". What pins on the brick translate to what voltages, the pins on the edge connector should read....etc.
Long story short is that I want to verify that the brick and ARII are 100% working before plugging in a known working pcb.
Or should I just wait for Dokert to finish the harness? ;)
The most important thing is to just make sure the +5vdc isnt waaayy too high or putting out a bunch of AC because of a bad filter cap or bridge rectifier. After that I'm somewhat daring. Maybe I'm just too lazy to take all the proper precautions before hooking up the cpu so maybe buy Dokerts setup. Not me though, I'm a rebel. Hopefully damage won't occur in the short amout of time it takes to test under load.
This is not a what to do, but does tell you what components do what.
Thank You Mr. Bob Roberts!!
http://www.therealbobroberts.net/aar2.html
then some things to check in here
http://forums.arcade-museum.com/showthread.php?t=79681
(next question---sense mod----nooooooooooooo not that topic again)
Great! Here's the site from Bob Roberts -
Atari Audio/Regulator Board Notes
by Bob Roberts
So many newbies entering the hobby this year with Atari games that I thought it was time to post something on using the kits for repairing the A/R boards to help avoid all the pitfalls. I'll try to cover all the Qs that have come up over the years.
Starting with the Asteroids A/R bd which used 1000uf caps for C9 & C10 where all post versions used 3300uf even though many of the schematics & part lists called out for the 1000ufs, the actual bd shipped in the cab had the 3300ufs installed. The kits contain the 3300uf caps which are universal & once installed in the A/R -01 it can be used anywhere you find an A/R or an A/R II-01. But for the physical size the A/R II-01 can be used in place of an A/R bd & that prompted many an op to saw the unused portion of the A/R II-01 bd completely off to accommodate their Asteroids or Football games. Some even cut down the A/R II-02 which can be used in place of any of the A/R or A/R II-xx versions.
The A/R II-02 kit covers all versions of the bds with parts leftover. So many people ordered the wrong kits when we had separate ones for each version of the A/R II-xx bds that we cutback to just the -02 kit for all... and for that matter, it will cover the A/R bds, too, although you have all the unneeded parts for the blank side leftover.
My Cap Map on these is often missed, so I'll put a link here. It lists many of my notes right on it, but I'll add them in here, as well. You can see from the Cap Map which parts are in the kit. To keep the cost to a minimum only the components that typically fail are included. The LM305 on these bds has been time proven, although there have been a few cases of failure, so it is not included nor are the TDA2002 amps which seem to be rock solid in this app. The 5 volt adjustment pot is not included along with the connectors & small passive components... all available on the Parts Page if you see that they are toast on your bd.
I guess the most helpful way to cover the common mistakes is to just make a do list of each component with notes.
1 Capacitors
This is basically for the newbies... caps are marked as to their positive & negative leads & they must be adhered to with the + (positive) & - (negative) symbols on the bd or as pic'd on the Cap Map.
2 Q1 LM305 Regulator
This part is not in the kit & it requires a steady hand and a good eye to align all eight legs for installation if need be & there is a tab marker on the case signifying the number 8 leg.
Do not overheat when soldering. Tack solder around the circle once & then repeat for final solder allowing each joint time to cool.
3 Q2 2N6107/TIP32
TO220 Insulator must be used.
Nylon 6-32 Machine Screw must be used.
Do not overtighten screw.
Be sure there is no short between the mounting tab & the heat sink.
4 Q3 2N3055
Metal machine screw must be used.
Case must be isolated from the heat sink.
It is important to tighten the mounting screws snuggly to complete the connection between the case (collector) and the trace below. Only one screw actually completes the circuit and for added stability you can connect a wire with a ring terminal to the second screw & solder the other end to the trace. You can also sand/file/brush the head of the main screw to solder it directly to the trace after it is mounted. The TO3 case is tank solid & not prone to damage from overtightening the mounting screws. As with any TO3 xsistor you always want to mount it before doing any soldering.
Always finish up this job by checking to make sure there is no short between the case & the heat sink.
5 Q5 TDA2002 Audio Amplifier
Not part of kit... take care not to overheat when soldering if you replace it.
No insulator.
Metal screw.
6 Q7 TDA2002 Audio Amplifier
No insulator.
Metal screw.
7 Q8 7812 12 Volt Regulator
No insulator.
Metal screw.
Tighten to hold in place, but do not overtighten. Overtightening of TO220 xsistors when a metal screw is used can damage internal device connections. Take care not to slip with tool & jab the plastic body which can have the same damage results.
8 Q9 7905 -5 Volt Regulator
Do not overtighten screw. Overtightening of nylon screws will strip the threads, so tighten just till the screw snugs up.
Unloaded output -15 volts. Many Atari games do not use the -5 volts even though their manual and/or schematic may show it & hence an unloaded -15 volts at the test point even when the game bd is in use. Pin 9 of P10 connector is the -5 volt output & many game harnesses don't even have a wire in this position.
Happy Gaming...
Hopefully someone will chime in on where to test the voltages on the brick and harness!
I thought someone may have done the work already. ;)
The note from Bob is part of it, and I have posted a bunch of testing instructions. Nothing along the lines of a flow chart per say. The work is done, but it is locked up in people's heads along with all those other little voices.:D
