is there a Playskool version of a Ms Pac transformer brick schematic out there?
vintagegamer
Donor 2024
Bear, Delaware
Once more, I can't use my current working Ms. Pac as an example to go off of, so I am asking you good people if there's a layman's doc that can tell me the wiring layout for an original Ms. Pac transformer brick? I want to see if someone's booged with the wiring on my current power brick.
Thanks!
Thanks!
Meh, found this.. reading it now ;)
http://www.therealbobroberts.net/mspac.html
I have an untested spare from a parted out cabinet if you're interested. Transformers on board, complete wiring harness, etc.. The transformers have some surface rust and are untested, but I'd price it to reflect that.
Thanks Joey, I will keep you in mind.
There's not much to it really. You have 120v going into the transformer and two 12vac lines, two 7vac lines coming out that go into the 4 position fuse block.
