is there a bypass for Xmen sound problem
cointech
Donor 3 years: 2018-2019, 2024
Arlington, Texas
someone told me years ago that you could wire in an external amp
on an xmen board and have sound again.
Is there a fix like that?
Eric
Coiintech
dose anyone know if the sound is still there if the chip is bad.
Couldn't you wire to the board where the sound come from the game roms
before the amp chip that is bad and then hook up an external amp and wire your speakers stero off of the amp?
Unfortunately nobody really knows for sure what that custom sound module does. There has been talk of documenting it, but nothing has happened yet. I've been able to bring sound back to 2 boards by replacing the surface mount caps on it. It would be nice is a workaround could also be made because not every board can be saved depending on how much damage leaking caps have already done.
