Is Nintendo Arm Wrestling same pinout as punchout/super punchout
Roadrunner000
Pittsburgh, Pennsylvania
I know the controls are somewhat different but can't find the manual I have to compare before I drag this cab out...I just want to test an Arm wrestling board I have to see if its working...I know some own this game...maybe you can chime in so I know if I have to modify anything before testing or just pop in the board to see if it boots up.
I thought that Arm Wrestling was a ROM swap for Punch Out boards. If not, the pinout is close enough that you can plug one into a Punch Out and get video and sound. I've done that, but I can't remember if I could get the controls to do anything.
Yeah..I found the manual and its same..controls somewhat different but game at least boots up..I have to pull game out to coin up to see if sound works too..but it should.
It's the same except for the CP wiring.
You should get pic and sound with no issues on PO, SPO and AW. I ran AW in a SPO cab until I got the trio done.
