Is neckboard pinout different on 33" monitors?
R3LL1K
Houston, Texas
I bought a Wei Ya chassis for a std res 26" monitor and decided I would try it in a 33" monitor that I had pulled the chassis from to recap. I went to power it on after hooking it up and it trips my GFI outlet. I unplugged the degauss coil, and it tripped it again. Pulled the yoke connector and it tripped again. The only thing I didn't do was pull the neckboard so I was wondering if the pinout is possibly different and if that might be what's causing the GFI to trip?
I tried this same chassis in another monitor and it worked fine. The only thing I haven't tried is the chassis for the 33" monitor on a 25" or 26" monitor.
Forgot to mention I ohm'd out the yoke and it falls within the chassis operating parameters so no issue there. It actually reads almost the same as the yoke on the K7191 that I tried this chassis out on as well.
They might be. Looking in the chart for my rejuvinator at some of the large tubes, some of them require a different neck connector adapter. What tube is it?
-Ian
It uses the CR-23. I believe it's an RCA tube, I'd have to check the model/part number though. I'll post it tonight after I get home.
Does it actually *use* the CR-23, or does it just have that kind of socket? Because if it really does list as CR-23 in the book, then no, it doesn't have a different pinout.
-Ian
Sorry, haven't had an opportunity to check out the tube but the chassis that's in there is an SI 325...
