The 2 wires that go up to my G07 monitor in my Ms Pac are wired as follows:
There is a white wire traveling from the top of one of the square things on the power brick (if you're looking in from the back of the machine, it's the square thing further away from you) to the connector going to the monitor chassis connector. The 2nd wire going to that connector traces back to the left fuse holder (the one that only holds 2 fuses), where it is connected to the fuse closest to you (again if you're at the back of the machine).
Is this the correct wiring for a monitor in this game? I've made no mods to it, and I'm just trying to make sure no prior owners got creative with the wiring.
Thanks!
Thanks!
