VectorJunkie
The LV6100 is made by Mark Spaeth, otherwise known as HudsonArcade here on KLOV. He's just mentioned having some done, so you'd better contact him in a hurry if you want some. Unfortunately, Mark doesn't have anything for me to link to (that I know of) detailing it.
The LV2000 is made by Jeff Hendrix. you can read more about it here:
http://www.geocities.com/jeffhendrix67/lv2000/
Here is some text from an old post or multiple posts from Mark on the LV6100.
These are made with fixed voltage regulators an all through-hole parts for better reliability.
$30 each or 4/$100.
It's a replacement for the low voltage power supply on the deflection board (+/-24V).
These voltages are also sent over to the HV cages to generate the high voltage, but if you're getting a good +/- 24-28V on your rails on the deflection board, and you're not getting any HV, then this won't help you.
I've got them on all of my monitors.
The common failure mechanism in the LV secition is the zeners or transistors blowing, and the rail voltages go too high, and can blow up other stuff on the board.
IC-based regulators can take a lot more abuse, and if they do die, they'll just stop output anything and the rail voltages just go away.
Attached is a picture he posted of one.
