is it quick and easy to install a lv6100 unit?
tron guy
Super Moderator
Staff member
Donor 12 years: 2011, 2015-2025
Eureka, California
It appears that it should be. Almost looks like I could install it while the deflection board is still attatched if I were real lazy.
Is there a quick tutorial on it? to make sure I don't mess it up.
Pull the deflection board. You need to remove about 12-15 parts from the chassis, then solder three spots when installing the LV6100 or LV2000....
thanks for the reply.
I guess I could google, lv6100 installation
and get a how-to huh?
I had just assumed it was remove the 2 big caps and replace with the lv unit.
5 spots... 3 posts (ground, and the emitter pins from the transistors removed when stripping the power section), and 2 wires (+/- 30V power input)
LV6100 is mine... and the name LV2000 makes no sense, since it's for a WG 19K6100, not a 19V2000 :)
LV6100 has +/-24V fixed voltage regulators, and all through-hole parts
LV2000 has adjustable regulators (shipped set to 26V?) and mostly surface mount parts... (and their surface mount diodes in particular seem to have a high failure rate)
And LV2000's are in stock at several vendors. :rolleyes:
Just a friendly reminder that I still need four LV6100s when you have time to get them built. :D
Thanks,
-VJ
Something tells me that Mark could make a bit of dough if he (or someone else) would build a website describing his parts, their prices, and the availability of each part.
I actually started capturing the content from his posts for my own reference. It comes in handy so you don't have to search for everything.
Once I get my fios installed (running cat5 around the house now), I'm going to look into getting a domain set up. I may end up setting up shop on adam's website though.
Congrats on the fios! I got it when I moved into my current house last year. Now that it is cooling down, I have a few more cat 5 drops to put in myself. I ran some conduit between two of my attics last year after it got hot like an idiot. It should be much easier to run the new drops since I can pull the lines through the conduit back to the attic over my patch panel. Anyway, good luck getting all the drops in.
-VJ
The LV6100 is made by Mark Spaeth, otherwise known as HudsonArcade here on KLOV. He's just mentioned having some done, so you'd better contact him in a hurry if you want some. Unfortunately, Mark doesn't have anything for me to link to (that I know of) detailing it.
The LV2000 is made by Jeff Hendrix. you can read more about it here:
http://www.geocities.com/jeffhendrix67/lv2000/
