Is correct?! Alien Crush was released as a JAMMA board???
http://mamedev.org/source/src/mame/drivers/uapce.c
http://mamedev.org/source/src/mame/drivers/uapce.c.html
United Amusement PC-Engine based hardware
Driver by Mariusz Wojcieszek
Thanks for Charles MacDonald for hardware docs
Overview
The system consists of a stock PC-Engine console, JAMMA interface board,
and several cables to connect certain pins from the PCE backplane connector
and pad connector to the interface board.
History
In 1989 United Amusement (a large operator of arcades in the US at that
time) developed a JAMMA interface for the PC-Engine with NEC's blessing. NEC
pulled funding for the project before mass production began, and it never
took off.
Driver notes:
- game time is controlled using software loop - with current clock it takes lots
of time until credit expires. Should Z80 clock be raised?
- tone played by jamma if board is not emulated
A kit owned by collector has following contents:
-x1 NOS boxed NEC arcade unit with all connectors
-x1 NOS boxed Keith Courage (custom/prototype PCB) with NOS marquee
-x1 Pacland standard Hucard WITH arcade cabinet marquee (this proves that while this is a standard card, it was sold by United Amusements with the intention of being used in the arcade unit)
-x1 Alien Crush standard Hucard with arcade "how to play" placard. Same as above.... proof this was sold for the arcade unit and not as a home card
-x1 Ninja Warriors standard Hucard
-x1 Victory Run standardd Hucard
-x1 Plexiglass control panel overlay (used)
In the February 1990 issue of Video Games & Computer Entertainment magazine, there was a list of
all of the available UA produced Hu-Cards (at the current time of the article was published).
The article mentions that the UA Hu-Cards were not compatible with the TG-16 gaming console.
- Keith Courage in the Alpha Zones
- World Class Baseball
- Blazing Lazers
- Alien Crush
- China Warrior
Blazing Lazers dump notes:
Game software
An EPROM-based HuCard manufactured by NEC (PCB ID: PWD-703) is used to
store the game program. It supports four uPD27C2001 (256Kx8) EPROMs as
well as 27C010s for total ROM capacity of 1MB down to 128K in various
configurations.
Jumper settings:
J1
Pos. 1 : Map IC1 to 000000-03FFFF (256K)
Pos. 2 : Map IC1 to 000000-01FFFF (128K)
J2
Pos. 1 : Map IC2 to 040000-07FFFF (256K)
Pos. 2 : Map IC2 to 080000-09FFFF (128K)
Pos. 3 : Map IC2 to 020000-03FFFF (128K)
J3
Pos. 1 : Map IC3 to 080000-0BFFFF (256K)
Pos. 2 : Map IC3 to 080000-09FFFF (128K)
Pos. 3 : Map IC3 to 040000-05FFFF (128K)
J4
Pos. 1 : Map IC4 to 0C0000-0FFFFF (256K)
Pos. 2 : Map IC4 to 0A0000-0BFFFF (128K)
Pos. 3 : Map IC4 to 060000-07FFFF (128K)
The board came with three EPROMs in the following configuration:
IC1 is a 27C010 mapped to 000000-01FFFF
IC2 is a 27C010 mapped to 020000-03FFFF
IC3 is a 27C010 mapped to 080000-09FFFF
IC4 is unpopulated
The software was a modified version of "Blazing Lazers", identical to the
USA retail version with the region check (offsets 0 through $18) patched
with NOP to remove it. The interface board is connected to a PC-Engine
console rather than a TurboGrafx-16, which would cause the region check to
fail.
Keith Courage In Alpha Zones: dump was made from PC-Engine game dump of US version,
with region check nop'ed out.
Alien Crush & Pac_Land: dumps made from PC-Engine dumps of JP versions
http://www.neo-geo.com/forums/showt...ografx-Jamma-arcade-unit-w-games-amp-marquees.
http://devkits.handheldmuseum.com/TurboGrafx_JAMMA/index.htm
Looks like it is just an Turbo in an arcade cabinet, nothing special.
