Is a A48ACB00X a viable tube swap candidate?
wsharp
Donor 2021, 2025
Pennsylvania
I'm not up on deciphering the information from the above website but it has a CR-23 adapter.
It's out of a Zenith SS1909W TV I bought expecting a 100 degree tube but it sadly has a 90 degree tube.
I'm not sure whether to keep the TV, sell it or recycle it.
Nope, not at all. I've only really dealt with vector monitors over the decades.
If the yoke and rings are separate then you can still use it in a vector monitor. It will work with an Amplifone or WG6100 yoke.
Ooh, you said ACB... that's a thin neck tube with yoke and rings as a single unit. If that's true it's likely 3/14 ohms and will work on any K7000 19" chassis but not vector. Don't toss it, that's a usable swap tube
