Teknotoyz
Is 4.95 volts enough to keep a Pole Position happy?
I need to decide if a ATX power supply (450 watt) is good enough to power a pole position?
It has plenty of amps (30) available, but I've heard 5.1v is "normal".
I was using the ATX as a test supply, but hate to buy another if I don't have to.
The game plays well using this supply except some abnormal audio in the music after a game, but I plan to rewire using test points to avoid power on the edge connectors.
So, do I need to buy an "arcade" supply, or should I proceed using the ATX?
