Inverted pic on a K7000
Waterborn
North Myrtle Beach, Florida
I just did a cap kit on a WG K7000 and everything is great, except for some reason the pic is upside down now. Any ideas why? And no, I did not put the monitor in backwards, only removed the chasis to do the cap exchange.
Wires
Are those the two black wires that go to the coil around the tube? If so, I tried them both ways, but still the same thing.
Not them. It is the 4 wire xonnector that is coming directly from the yoke and plugs into the chassis. there is 2 wide pins and 2 narrow pins. Yhe connectoe must ne in 2 pieces for it to be reversed. Male sure you dont invert the wide connector on the narrow one. You will only have to flip one of them around depending on if it inverted or mirrored.
Find your yellow and green wire positions from the yoke and swap them. that will put it right side up. if it is backwards after that, swap the red and blue wire positions from the yoke...
Well, I must have been too tired when working on this last night, cause no matter how I switched up the wires, I either had a mirror image or upside down screen. Turned the game on today, screen upside down. Swapped two wires and voila, just fine. Thanks for the help with this. BTW, the yoke wires were indeed split into two connectors, creating my issue in the first place.
