Robotron Jon
The interlock switch for the back door of my Asteroids Deluxe is toast. It was damaged at some point and I took it out today to take a look at it and it cannot be repaired - plastic is broken, and metal pieces have fallen out. So I want to either bypass it or find another switch.
Any idea where to get another switch? I see that Arcade Boneyard has them.
I was also thinking bypass. It was two back and two white wires connected to four connectors on the bypass, plus a green ground wire. I am assuming all the bypass does is break the white and black circuits and so I have to simply connect the black wire to the black wire and the white wire to the white wire to bypass. Can anyone confirm this?
