Interesting read about Bally Midway sound boards
tec9
New Britain, Pennsylvania
Thought this might be interesting to those who have these machines:
Hey all-
Thought this would be good info to pass along, to see if your machine could use this mod, look at the game list at the bottom. This is a note from Bally Midways service center:
Subjuect:
Premature failing of the 7533 DAC's on the sound boards. During extensive research on the sound boards Digital to Analog converter circuit, we have discovered a transient condition which may result in premature failure of this part.
Cause:
The condition is dus to overstressed metalization related to pin 1 on this chip. The situation occurs on power-down when the Vcc begins to fall and reaches about 1.5 volts. At this time, the voltage on pin 1 exceeds Vcc for a fraction of a second. The DAC is not designed to withstand this condition.
Cure:
Remove the 47uf capacitor connected to pin 1 of this chip. This will eliminate the transient condition on the circuit, and testing indicates that this removal has no negative effect on the overall operation of the circuit.
Board names: Remove Capacitor
1. Sounds Good C122
2-Cheap Squeak Deluxe C122
3-Artificial Artist C122
4-Turbo Cheap Squeak C12
5-T.C.S. Pinball C30
6-Sounds Deluxe Pinball C12
Pinballs List
Black Belt #5
City Slicker #5
Dungeons and Dragons #6
Escape from the Lost World #6
Hardbody #5
Heavy Metal #6
Motordome #5
Party Animal #6
Special Force #6
Strange Science #5
Video Games List
Demo Derby #4
Max RPM #4
Power Drive #1
Rampage #1
Sarge #4
Spy Hunter #2
Spy Hunter 2 #1 +#4
Star Guards #1
Xenophobe #1
Zwackery #3
Subject:
Cause:
Cure:
That's pretty bizarre.
The AD7533 is supposed to be a R-2R current-mode DAC, but they've got the 2 current steering outputs wired to vdd and ground and are using the vref pin as an output instead of an input to make it a voltage-mode DAC instead of just buffering the current with an amp and converting it to a voltage.
But yeah... the way the 'soft powerup' circuit hanging off pin 1 is done (to prevent a pop on powerup), Pin 1 will drop slower than Vcc (+12V) when the game's turned off, and if it's higher than a diode drop, the transistors in the R2R DAC switches can latch up and melt themselves.
Probably easier to just put a reverse biased schottky between +12 and Pin 1 so Pin 1 never goes more than about 2-300mV above +12 during powerdown which is enough to prevent latchup, but still have the soft-power design work.
I responded to a post referring to this post. Here is an ap note that covers the topic. Skip to the last page for the solutions if you want to forego the theory:
http://www.analog.com/media/en/technical-documentation/application-notes/20809090AN109.pdf
None of those 'solutions' are relevant to how midway (mis)designed the circuit. The series diode on vdda could hinder latchup, but it doesn't fix the primary issue of vref>vdda+vbe, and actually makes it worse since it'll drop vdda by a vbe, so if you're going to do that, you at least need to do the same to the +12v to vdda connection.
So the Midway engineering fix recommended in the service bulletin will fix the issue or won't?
