interest? - Amplifone HV board harness repro
joeycuda
Madison, Alabama
I'm not finished with the deflection board harness repros, but thought I'd gauge interest. I've got 2 of Dezbaz' HV board blanks, and I will need a couple of harnesses. IF I made some of these up, it would be correct color wire, correct gauge, tied at the same spots, installing the two Molex connectors, the ties with the screw hole to attach to cabinet sides, but would NOT include the neck connector. You would need Dezbaz' repro neck board solution, so it would really be geared for that repro, but I suppose would work if you have an original neck connector.
You would solder to the HV board and deal with the neck connector. I would be:
-putting the proper length/color of wire together
-wire ties/bundles, etc matched to an original harness.
-molex connectors
Not sure on price, but it would definitely be more than the deflection harness, as there's a lot more wire there.
Any interest?
I will help Joey by posting links
Neck Connector
HV Assembly Thread / Guide
http://forums.arcade-museum.com/showthread.php?p=2342701#post2342701
I will post a completed Harness pic soon (I didn't bother with correct colors, so it will just show the idea
NOTE, in the Neck connector pic, I will be deleting the straight molex connector, in favor of direct soldering
I didn't do this as there didn't seem to be much interest. I can revisit this in a few weeks as I'm moving, so hobbies are going on the backburner for the most part.
Well when I get my parts. The store I frequent only sells molex connectors in bags of ten so with a little research I might just make up as many cables as I have parts for.
Other than the manual. Does anybody have the pin out for this harness?
I have an Amplifone page with all these diagrams, pinouts and info on it
http://www.dsbelec.iinet.net.au/amplifoneDB_Backup.htm
Specifically the diagram for the new board is here
I am starting production with these as soon as I get my crimping tool.
Proper guage and rating for wire. 20 AWG and molex connectors crimped. Length of wire between HV board and neck board will be the same as the focus wire.
