Instant insulated spade connector.
r3m
Pennsylvania
Well when you need a spade connector that isn't insulated and only have a regular spade here is a tip for just that.
This is the type of spade connector I want insulated.
Take some shrink tube and put it over the connector and make sure it's flush and cut off the excess.
Heat it up with a lighter. Quick, easy, and cheap.
Now i have more of a reason to use the bigger diameter heat shrink you get in the combo packs. Thanks lol...........sometimes the simplest ideas can always be hiding right under your nose until someone points it out.
No problem. I know what you mean. lol It's one of those things where you say "Ugh.. Why didn't I think of that?"
