Okay, so I bought this World Rally which was playing blind. I recapped the chassis and neck board and replaced the flyback and HOT as well. I had noticed that the flyback had a small crack in the old one so I decided to replace it. When changing the flyback I noticed the chassis fuse was blown. I assumed that it got blown because the flyback might have been bad. I also put in a new power supply. Anyways, I turned it on and it blew the fuse instantly. After reading through the forum and some online links, it appears that I need to check a bunch of the following:
1) Check for short on C38.
2) Ohm out HOT (centre and third pin. If near 0 then it's shorted)
3) Check large ceramic resister parallel to VR.
4) Check C55, C56, C57
5) Check R84, R85, R86
6) Check C36, C38
7) Check diodes 19-24
8) Check D18.
I'm new to this stuff so just to make sure I understand this correctly, I need to desolder these capacitors, resistors and diodes to test them properly correct? I should mention that I don't have an in-circuit ESR reader, just a regular multimeter. Could it just be that my voltage regulator got fried prior to when I bought the game? Should I pull and test that first before anything else? Any other suggestions would be appreciated. Thanks.
Robert
6) Check C36, C38
8) Check D18.
Robert
