noClip
Installing Iso Transfomer, Power Supply and Monitor Chassis (G07)
Hi guys
I picked up an empty cab from a fellow klover that was missing the power supply, isolation transformer and monitor chassis.
I did some research and this cab was originally an Asteroids cab and the iso transformer was mounted with the power supply when it was removed.
I purchased a switching power supply and an iso transformer and a rebuilt chassis, so now i need to put it all together. Unfortunately when this stuff was removed, none of the wires were labeled so i will have to trace each wire back to the harness for the PS, but just looking at everything there is atleast 1 connector i dont know what to do with. The G07 Chassis has a molex plug that i assumed was for power, but i dont see anywhere for this to plug into. Also, I see a ground wire coming out of the monitor and off the monitor mount that i dont know where to ground to.
Here are some pics: http://s798.photobucket.com/albums/yy265/sweetdave40/asteroids cabinet pics/
Sorry if they arent informative enough, if you need a better pic of anything, let me know and i can try and supply them. My main concern is that there arent any fuses in the cab, and i dont want to blow up anything hooking it up the wrong way.
Any help would be appreciated
Cheers,
-Dave
Hi guys
Cheers,
-Dave
