Inputs and Outputs
JeepMonkey
Kansas City, Missouri
Does anyone have a good idea how many digital inputs and outputs a modern pinball controller has?
Not including things like audio, DMD, etc.
I guess I should say playfield IO.
Well, 8x8 matrices in most modern games for switches, lamps, and solenoids. 64 inputs and/or outputs per matrix.
Some games had auxiliary boards to increase number of available ins and outs.
Depends on the system. As far as the playfield is concerned the only thing resembling a digital input to the MPU is the switch returns. Everything else going out to the playfield will be an output. Solenoids or lamps.
So... why do you ask? If you give more detail on why you're asking you might get a more informative answer.
