Info needed on Defender pcb metal mounting plate..
andykmv
Kilmore, Vic, Australia
I'm in the early stages of a project to build a repro defender using original defender boards, and I need to have a plate cut to mount the power supply board, isolation transformers etc to.
Can anyone please provide some accurate measurements ? The following dimensions are needed:
- the power supply metal plate (length, width and thickness)
- the distance of the pcb standoff holes from two adjacent sides ?
- the standoff height between the Defender PCB and the metal plate ?
Thank you and Cheers!
The power supply "plate" isn't really a plate, per se, but a square frame with holes to bolt down the PS board.
The other plate is similar to the standard Williams mounting plates. I think the standoffs are about 1/2-3/4".
May be easier to just buy a plate from someone...
