In need of Wayne Gretzky 3D hockey Dipswitch settings
BRI71
Minnesota
I've searched high and low online for info about my Gretzky 3D Hockey board. There is no info out there. Does anybody have the D/S settings for this game. It uses the Midway "Seatle" board... same as Blitz football, however, the D/S settings do not match.
It looks like all dip switches should be off according to this pic......
From the manual:
"All instruction variables for this game are software selectable from the menu system. Each of the DIP Switches should be set to its OFF position (Factory default) for the program to operate properly."
I'm not really having problems running the game, but I want to switch between a 2 player game and 4 player game, and switch between 8-way and 49-way controllers, and set the game to freeplay mode, etc.
One of the dipswitches should put me into a test/setup mode to allow me to change game parameters, and I have no idea which d/s does that.
Did you try using the service menu button inside the coin door?
Sweet, I added a switch onto the Test wire, and I'm in set-up mode! Now I just need a new battery so my settings will be saved.
I did get into another hardware diagnostic screen when I was flipping switches yesterday. There has to be a d/s diagram in the manual, hmmm.
