In need of some interior photographs of a Rock-Ola Trilogy 4000X Jukebox
Shawn1976
Donor 10 years: 2016-2025
Saint Augustine, Florida
Hello everyone.
Now that I was able to access the inside of the jukebox I am now starting to fix any problems that I see, which looking at everything looks to be small fixes.
The problem that I'm currently having is at the bottom inside of the game there is a fluorescent bulb surrounded by a colorful acetate that is suppose to rotate to display off of the silver colored CD's at the bottom inside of the game.
The rotation is accomplished by a small motor that is located at the bottom left which slowly rotates a clear plastic cylinder that the acetate is encased in.
Well when I opened the game, the motor to rotate the clear plastic cylinder was disconnected (which I did plug in to test and works 100%) and the right side of the tube was taped with a large amount of electrical tape. I was able to carefully remove the entire assembly and saw that there was a black piece of plastic that was wrapped in the black electrical tape on the right side, but I'm not sure if its broken or where exactly it goes.
Before I try and decipher exactly how this is used to turn the cylinder, I wanted a basis to find out if I'm missing anything which is why I'm requesting the photographs.
Just a couple of clear photos of the bottom left and bottom right of the connections where the front cylinder that rotates would be great.
I can also supply photos on my end of the areas I'm asking for, if my message isn't clear.
Anyone that could help me would be greatly appreciated.
Interior photos of mine.
I do also have the plastic cylinder beer that houses the colorful acetate and the bulb.
I also had a black piece of plastic (last photos) I'm assuming is broken that I'd like to get hood photos of an intact one.IMG_6160.jpegIMG_6162.jpegIMG_6164.jpegIMG_6163.jpeg
