FS Game: In MD: NBA Fastbreak pin project 1150 obo
GuidoTorpedo
Maryland
Rating - 99.1%
105   1   0
It boots and starts a game. Needs shopped. A little battery acid on the holder, NOT on the board. It holds memory. Game is complete.
Cabinet is not bad. Playfield has a Mylar on it that is torn in a few places, and should probably be pulled. Playfield itself, aside from Mylar, is not bad.
Display does not work because of an issue on the video section of the A/V board. I do not know the working status of the display. Also, the shot Clock goes in and out, probably as a result of whatever needs repair on that board. There is a slight short under the pf that causes a row of feature lights to stay lit. I'm 90% sure it is not a board problem since I tried a different known working driver board in there and the lights stayed on.
1150 or best reasonable offer. Located in northern Baltimore county, md.
Thanks!
MikeImageUploadedByTapatalk1341067206.448846.jpgImageUploadedByTapatalk1341067225.046455.jpgImageUploadedByTapatalk1341067243.028438.jpgImageUploadedByTapatalk1341067257.492664.jpgImageUploadedByTapatalk1341067271.828273.jpg
