kerri369
just curious with all the confusion of positive and negative, what would happen if they were installed improperly?
The caps in the power supply would pop... semiconductors would short and the fuse would blow... the bridge may even short out.
Uh... why do you think the bridge would/could short out?
If it was installed backwards where +/- were reversed and things shorted... it could damage the bridge if the current pull was too much.
Fuses could go first but that all depends on what size fuse is in there. Is it really a fuse or is it wrapped in aluminum foil? Is it oversized?![]()
alright, let me get this straight, if it was installed without checking and everything works does that mean it was installed properly? i have a game that has a new rectifier installed and works does that mean they did it right? (when i got the game it came with all the old replaced parts in a bag)
