Image "bleeding" on a NEC XM-2960. any help?
milkit
Mesquite, Texas
I just picked up an NEC XM-2960 29" monitor off craigslist for a MAME cabinet. Of course, guy didnt have a cable for me to test it but said I could bring it back if I had problems. (purchased from a church)
Anyways, just got it home and the image looks like its bleeding or running. Any clue if this is a major issue or an easy fix? I tried to take a decent photo showing what its doing.
If i can fix it easy, I'd like to. I had to borrow a truck to pick it up and its kind of far from me, but I can always return as a last resort.
NEC Technologies' MultiSync Plus Series presentation monitors incorporate the latest advances in large-screen monitor technology to deliver high-impact presentations and information display. Combining superior image quality, system integration capabilities and user-friendly features, these monitors are designed to provide no-compromise performance whether used alone or as a part of a room system. The MultiSync Plus Series are the large-screen monitors of choice for conference rooms, training facilities, group videoconferencing, classrooms, trade shows and public display as well as rental duty. In addition, direct NTSC video compatibility and built-in stereo audio capability make these monitors true multimedia display powerhouses that will enhance your ability to communicate ideas and information to small groups. ??The MultiSync XM29 Plus is the first 27" viewable image size presentation monitor to offer a .60mm dot pitch CRT, which delivers a better display of 1024 x 768 resolution...
MPN XM2960
Key Features
Monitor Type What is "Monitor Type"? CRT
Size 29 inch
Max. Resolution What is "Max. Resolution"? 1280 x 1024
Family Line NEC MultiSync
Connectivity
Audio Output Speaker(s)
Technical Features
Dot Pitch What is "Dot Pitch"? 0.6 mm
Dimensions
Height 21 in.
Width 25.41 in.
Depth 20.41 in.
Weight 117.97 lb.
i adjusted pretty much everything but contract. It didnt seem to let me adjust the contract. It looked like it was stuck at either the highest or lowest setting (full bar) and pressing + and - didnt do anything like it did with brightness/etc.
ill keep trying!
nevermind :) the contrast was alll the way up. It was being weird though. On brightness one push of + or - added or subtracted a bar of brightness. However contrast I had to press about 30 times to lower it one bar. So, I sat there for several minutes pressing it until it finally came down to a reasonable level and the picture looks loads better.
