You are using an out of date browser. It may not display this or other websites correctly. You should upgrade or use an alternative browser.
Museum of the Game® & International Arcade Museum® Forums
Back in 2022 I picked up a Berzerk that survived, it was missing the monitor, back door, coinbox, the cabinet was falling apart a little but the main aspects of it, the bones were pretty good.
I'd like for it to run on all original hardware as it did in 1980 or else it will be a failure, that's where my soft spot for it is, in the hardware, so this thread will be dedicated to that first and foremost.
Many of the good chips were robbed from the boards so I've been collecting everything for it ever since that was missing, including what I needed to repair everything and also the original batstick which I hope to reassemble.
I'll start with reinforcing the cabinet, getting that square, putting leg levelers on it so can move it around a bit easier.
