Ikari Warriors joystick weirdness....
viewsonix
Virginia
I have an Ikari Warriors machine, and the Player 2 joystick doesn't like to go left, for some reason.
Here is a pic of the type of joystick I have. Note that this is a completely different type of joystick than the Player 1 stick. The Player 1 stick has a different type of control on the bottom.
Can I disassemble or clean out this type of joystick? Or do I need to replace it completely?
No, just sounds like a bad microswitch, cheap to replace. Remove the joystick carefully and replace the bad microswitch, or actually before that check the connectors are making good contact on the microswitch before you replace it.
