IGT Triple Double Diamond and Wild Cherry
Minelayer
California
I just got both of these machines and noticed that it makes all the sounds I expect it to make except when the reel spins.
Anyone have an idea why this may be the case?
Yeah, you're right. I believe it is switch 3.
Unfortunately it was already in the ON position. Switched it off, reinserted the board and back, but no luck.
Try this first...
"if you want your machine to have reel sound open he door, press the self test button you will see a 2-0 push the spin button you will get a 2-1 then close the door and it will have sound.
be sure their are no credits on the machine."
The test button is a very small white button. Its usually located on the back of the interior on/off switch but some games have it in different locations.
Then this...
"Depending on the SP chip in use, you may have to reach zero credits (play them out or cash them out) before the new dip setting will take effect. In addition, newer SP chips ignore the dip switches and use a setting to turn reel sounds on or off. "
Riptor, you are truly awesome.
I followed your instructions and it worked like a charm on both machines.
You totally made my day. Thank you.
