Figure out the maximum coins you can bet at once, which would be shown on the award glass. Probably 2 or 3 coin max, which is known as 2CM or 3CM.
After clicking that, click Haywire.
After clicking that, the prog# column shows a 6 digit number starting with SS. That's the odds chip for your slot. The second column shows the odds, they're sorted highest to lowest.
Several of the vendors on the Newlifegames site should be able to sell you a new odds chip. I'd also reccomend getting 'set' and 'clear' chips as well. The folks on that website are really helpful.
I agree with going to newlifegames, but the quick answer to your question is get a different odds chip, I'm sure you can find someone over there to sell you one.
(ooops, sorry, same answer above..)
