I have a double red, white and blue giving me a #43 error code. The second and third reels slowly spin and the first is stationary. I switched the plugs in the bottom but no change in anything. I then swapped the second and third reels with each other but still no changes (same error code and reels 2 and 3 spinning slowly). I then swapped out reel 1 for reel three but same error code and same slow spin on reels 2 and 3. The machine had been dormant and wasn't working when I got it so I put in a new battery to fix error code #12 and a clear chip to fix the 61 / 61-1 loop (with help looking through these past form threads), and everything was finally working and machine was being used for a couple days of use with no issues before it suddenly starting doing this. Any suggestions on what to try next? I saw suggestion on checking the optics but am not sure where those are. Thanks
