I just got a B&K 480 rejuvenator. I have no manual, but I have read the condensed instructions / setup chart PDF that's still on B&K's site.
In step 2 of the 470/480 test procedure, it says "Excessive H-K leakage cannot be repaired, use isolation transformer." Does this mean that using an iso will correct the issue, or does it mean that you should splice in a separate power supply for the heater?
In step 4 of the 470/480 test procedure, it reads "Adjust each G2 control until meter rises ONE DIVISION." What exactly is one division? Should I be aiming for the second tick on the far left of the meter or 0 or good/bad or what?
