IGHT Video Poker Repair Help
Zud
Madelia, Minnesota
IGT Video Poker Repair Help
Ok I am not sure if this is the right place for this. I just picked up a back-to-back IGT video poker game. It is model 12700. I have 2 sets of boards for the entire machine. I cannot get this to work. Not sure if all the boards are good. All I was able to get running was the monitor. I have 1 good and 2 bad. Anyone have a manual for this or a good idea for trouble shooting? All I get is a blue screen and no sound. No lights on the buttons either. The monitor does work. Thanks in advance for any and all help.
And yes I already posted this in New Life Games. :rolleyes:
Check all your fuses, look for a battery, see if you can figure out if the power supply is working for the game boards, reseat any chips, etc.
Make sure the screen isn't blue because of a monitor issue. Can you coin up at all?
Fuses are good. Batteries look good. Have not set-up coinage. I guess I should plug that in. :rolleyes: Hard to work in the tight space they give you for this damn thing. My next day to work on it will be Saturday or Sunday. :( I was hoping I'd at least get something on the screen.
Poker machine
If you can post a picture of the machine and of the boards so I can identify exactly which model it is I can help you get up and running.
fortune 1 need help
I have a fortune 1 model 704, it was working fine, then the coin drop stopped working, when you put a coin in it, it does not register, everything else is working good, any ideas?
thanks
Reset
Sounds like corrupt software I think a EPROM clear chip will make the difference. I am not home right now or else would look up further for you. But I have sen this before with a older bally machine.. Ps I wouldn't trust that battery. It may check out ok I would still replace it then do the ram reset.
It sounds like they are complete and a fun one.
