Identify this PCB?
I was thinking that it might be a bootleg something.. I have 5 of these boards that are very similar. All have no identification numbers whatsoever..
The thing is, that board looks almost identical to a Galaxian board - although the daughter card is different, and there is no solder mask. It might not even be Galaxian - it might be one of the numerous other bootleg games that ran on the same hardware.
If you have a ROM burner, you can read in one of the ROM chips and use RomIdent to figure out what it is (provided it's in the database).
I would double check to be sure the power matches up with Galaxian, and if so, I'd say it's reasonable to assume it matches the Galaxian pinout, and try it out.
-Ian
-Ian
Looks like it also has the circuitry for 7 volts AC power input (which is converted to DC) so you may need to carry out an AC to DC mod if powering it with a standard DC PSU (assuming it hasn't already been modded). There's various ways to do this, everything from a simple wire jumper to removing diodes and bridging their locations with wire jumpers. A Google search for 'Galaxian AC DC mod' will give you the relevant info.
