shardian
Pins always be breakin, yo!
Those vids always play fine 99% of the time I turn them on.
Like I said. If you're buying good condition shopped out pins then maintenance should be pretty straight forward. If you had purchased restored games with rebuilt monitors the same would be true of the vids. Over the life of the machine pins will require far more work. That's undeniable.
Restoring a rough pin is about 10x more work than fixing a rough arcade game though.. Much more in the way of cabinet restoration, often more connectors, and many more sub-assemblies. I still haven't finished this project, but a lot of work went in the before to after on this cheap rough project- total strip and repaint, new ground braid, etc..:
Could not agree more. I've restored dozens of both.
Nice Dracula. I have one too![]()
Thanks. The cabinet repaint is done. I'm to the point where I need to clearcoat the touched up playfield, reassemble and finish the boards. Rebuilt the rectifier board and solenoid driver, but I only get 2 flashes on the MPU. Gotta work on it soon..
3rd flash is the 5101 RAM. If you have board problems ask in the pinball forum. I have a couple of boards that aid in troubleshooting but you probably don't need those if you're only fixing one MPU.
One day in the future, I'll most likely get my hands on an F-14 Tomcat.
I look forward to this day.![]()
The one and only pin I've restored newer than 70s/early 80s was an F-14.
It was rough when I bought it, cabinet damage, filthy, things not working. I ended up pulling the full mylar, doing insert decals and auto clearcoat. Touched up cabinet, replaced 2 displays, full playfield restore. I spent a year working on it. I sold it, but miss it. I don't think you'd regret buying it.. it's a heck of a light show with all the flashers. The sounds are great too. I really enjoyed playing it while I had it.
