ID Hantarex HELP!
wmacmonagle
Donor 2012
Rosamond, California
I have hantarex and has problem with arcadevga card. I was not able to get it to work with hantarex and trying to figure which it is.. is it polo or just standard res or low res or high res or etc..
im having hard time to have this work with 640 x 480. the monitor will flicker/shaking. if i adjust to 320 x 240. shake stop and show perfect.
i know it s 25 inch monitor hantarex.
any help will be appreciated. i know this hantarex should work with 640 x 480 any feedbacks would be appreciated.
photo chassis attached.
maybe you need that flyback and cap kit for the mtc9000 I just bought.
the one i have just like that is labeled mtc9000 and its for a 27" are the flybacks different between the 9000 and the 9110?
IIRC, the only difference between the 9000 and the 9110 is the fan/temperature sensor/associated circuitry. Oddly enough, every 9110 chassis I've ever worked on (not many, mind you)....has a factory 9000 label. Go figure.
Edward
