ICE Hoop Fever Firmware request
Bump, this would be interesting to check out. We added DBAs to our Hoop Fevers (harness is stock from factory) but they don't handle multiple pulses too well, even when DBA set as slow as it can go... so it takes singles and eats the rest.
2411? Or 2511? I'm having troubld
For Mars bill acceptors? 2400 series only takes $1s and $5s these days but use pulse mode which is what you want. I think 2500 series is serial data only?
We also tried ICTs that have a useful pulse speed selection by dip switch... even the slowest speed (150ms on & 150ms off) seems to be too fast. As I mentioned $1s work.
The settings on ours have separate channels for coin and bills; if yours doesn't, then you have to wire it in to the coin input and try to get 4 pulses per dollar, which leads you into the pulse speed problem. :(
