Ice Cold Beer switch issue
dtitus
Jacksonville, Florida
I'm hoping someone can help me out with an issue I'm having with my Ice Cold Beer.
The game starts and plays fine until the second hole. Then when that switch is tripped it reads as a miss.
I ran the switch tests and they all came back as correct and working. I tried a new switch (and swapped with #1) but with no difference. Voltage on the 5v line was 4.96 and 12v was right at 12.
Any suggestions for something else to check would be appreciated.
When you say it passes in switch test, is this with you manually activating it with your finger, or with the ball actually going thru the hole? If the switch is off adjustment (or the ball is the wrong size), the ball may not be fully closing the switch for it to register...
There is a self diagnostic listed in the manual where you walk through each switch and it shows on the display if it registered correctly. I did the test for each switch and all of them displayed they were working.
