ice cold beer start button light
cleverlyj
Northglenn, Colorado
can someone tell me what wires should be running to the socket? my socket is gone and there is no wiring that i can obviously see. i looked at the ICB manual but it doesn't give a clear pinout that i could see...
edit - i've got the cab all taped up and covered right now cause i'm repairing some broken off pieces and doing some touch up, but the harness on the control panel is missing the two pins that i assume supply the voltage to the light... i'll have to dig into this more once i get it back together.
My parts CP has the purple feeding the light. dunno how to read the pins on the connector, but it is 2nd to edge, middle row, next to the empty hole. let me know if that doesn't help ;-)
You want me to take pics for you, I can do that if needed...
Its the purple wire, pin 11 of the connector.
Its funny, saw this thread and I was thinking "ICB has a lighted button?" Looked at mine and the ground wire for the light has broken off. Guess it was like that when I got it and its never worked since I have had it.
ok. so i have the purple wire @ pin 11, and i have a black wire @ pin 10 with the connector broken off, just bare wire. is that the return or ground for the socket with the purple wire? can anyone confirm this?
just to update the fix in case anyone searches for this someday, ran the black from pin 10 and the purple from pin 11 to a new socket and all is well.
