so, the bars on my ICB occasionally stick on the up and down bars and aren't as smooth as they should be, and stick a little. i used a little wd40 before but it didn't really last long.
anyways - the manual calls for silicone spray, so i got some. should i use that to also lube the telescoping rod that the ball rides on too?
secondly, on each end of the telescoping bar where it connects to the cable assembly there are those little pads that serve as a buffer and contact the playfield when the bar moves up and down. i can't tell if that is sticking, but there are vertical marks on the left side of the playfield consistent with that pad indicaticating that the pad may be rubbing against it and also hanging it up.
any tips on that? i use mil wax i think on pinball machines, is it a good idea to just put a few coats of that on the playfield to help the bar move smoother?
