WiiKnee
Hello, new to vids but am experienced in electronics.
I just got an Icade 60-in-1 in the mail, hooked it up to my jamma cab and am getting nothing (no sound, monitor doesn't even budge). LED5 turns on and stays solid; there are two other LEDs on the PCB that briefly flash when power is turned on, then got out. My jamma cab is fully functional with good, clean power; all other jamma PCBs work just fine. So, I hooked up the Icade to my test bed (+5v and ground only)- low and behold, it appears to be working, the two other LEDs now flash orange, then yellow after what I assume is the boot process, so I am blanking just fine. Using the same power supply (just to be certain it is not a power supply issue), I put it in my cab, and the same thing happens, no blanking signal, dead.
So, apparently, this board will not operate when my jamma harness is connected but will operate without a jamma harness. I am drawing a complete blank. Any ideas?
Thanks!
Chuck
Thanks!
Chuck
