icade 60n1 "fast" mspac not fast?
msignor
Sparta, New Jersey
Just finally got my frankenstein up and running this weekend. I noticed that my icade 60 in 1 seems to have two identical ms pac versions on it. I try the standard mspac which works as expected. Then I go down to page 10 and try "v2" which is listed as "fast" and it is not fast at all. literally seems like the same exact file as the game listed on page 1.
Am I missing something here?
thanks!
Yep. They are both set with the same settings when you get the board. They are not labled as "fast" or "slow" on the menu because some folks like to put the fast ones up front and the slow ones at the end (like me). You go into the menu and set them for how you want them...
Thx guys. I should have guessed that some additional config was required, lol. I did the same as modessitt and put the fast up front :). I was surprised to see that the new life was set for 15k or off.. need to check that out some more.
I also had to set Qix to 75% coverage. 60% was just way too easy :-D
Now I just need to fabricate some new sheetmetal CP as the one I am running now is ghettoooooo...Cab is SO ugly and pieced together.. I feel like putting some band-aids on it would make it look better.. but now at least it's an original universal cab (shell) that was saved from the dump..
Maybe I'll post some pics later tonight.
