Icade 60-in-1 Joystick Problem
Stoonfer
New Hampshire
It's been awhile since I wired a cab for a multicade but it's pretty simple, until tonight. Got everything wired-up, adjusted the sound and free play, and went to play a game of galaga and the game will go left when pointing the joystick right and right when pointing left. In ms pacman it does the same and in addition will not go up or down.
I am able to navigate the menu with the joystick fine and the last screen has a test for all the inputs and they check fine. Even if I do switch of the wiring on the joystick left and right it still does the opposite but only during game play. Anyone seen this before?
I agree with Tron guy. If the test mode shows it's where it has to be, it should work. The only input you can change by the menu is the trackball direction.
Any update to this?
I have the exact same thing as the first post going on with a new 60:1 I just got. Test screen shows all 4 joustick directions are working, menu field works fine with the joystick up and down...same issues when I play a game, Left/right mixed up and no up/down. How did you fix this?
Updates?
Please forgive a noob for reviving an ancient thread but I'm desperate. I am experiencing this exact problem. Has anyone found a solution? I have tried 3 different 60 in 1 boards, 2 joysticks and verified my wiring 10 times but the problem continues! Thanks in advance for the help!!!
