IC identification when the part number has been removed
It's not because I'm full of myself, simply I'm sure of what I said.That's all.
fair enough.
FWIW, I hope you are right. Need to probe the part on the board then find a donor. Hopefully a bad board or a Vigilante (cuz the game sucks!)
Before swapping the part, first check supply pins at least, just to be sure.And check also orientation before soldering it, pin 1 has a dot circle on package.
Before swapping the part, first check supply pins at least, just to be sure.And check also orientation before soldering it, pin 1has a dot circle on package.
Oh yeah, that was the plan.
I'd say caius is probably right about it being a KNA91H014... just by looking at the clusters of pins/traces, they seem to match (like pins 3-10, 48-50, etc). You should definitely verify others, like VCC/GND before swapping though.
DogP
close up of the chip that I've been talking about. I didnt get a chance to probe it, was working on the games in the second pic all day.
oops........
