Can anyone explain to me Ian's Horizontal Curl Mod? It didn't make much sense so I ended up following Bob Robert's instructions.
Ian's says:
Horizontal Curl Modification
1) Remove and discard C501
2) Remove C303 and install it in C501 with the positive lead in the hole closet to the edge of the PCB
a. See included Cap Map for orientation
3) Install included C303 in the now empty C303 holes
Step 2 doesn't make sense. The C303 from the board is a ceramic capacitor with no polarity, there is no positive lead.
His cap map also shows the new C303 being installed with opposite polarity as Bob Roberts' instructions. Ian's instructions also make no mention of filling in the outside hole like Bob does.
Is Ian's way just a different way of doing it or is it a mistake? I would hate to see someone ruin their chassis if this is a mistake.
Ian's says:
